- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mobile devices randomly getting intermittent Wi-Fi connectivity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This morning I noticed my iPhone was still connected to my Wi-Fi network but was unable to get connectivity.
After some general basic troubleshooting including, forgetting the network and reconnecting the device, power cycling the device, the issue appeared to be resolved.
However, fast forward a few hours later and the issue reappeared intermittently, following the same troubleshooting steps as before seemed to resolve the issue again, but only for about 30 - 60 min before becoming a persistent issue.
As a result I have also attempted to power cycle the CAX80, verified firmware up to date. Also verified via the router admin that it can see the device connected via the 5Ghz, the IP and MAC match what the iPhone shows, no duplicate information present, and access is allowed.
After mentioning this situation, my wife also reported the same issue with her iPhone briefly yesterday.
All other devices seem to be unaffected and working as normal. We currently have 10 - 11 devices via Wi-Fi frequently and peak between 13 - 14 when everyone is present.
At this point I'm unsure how to troubleshoot this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mobile devices randomly getting intermittent Wi-Fi connectivity.
What FW version is loaded?
What channels are you using on 2.4 and 5Ghz? Try 1 and 40.
Set 20/40Mhz Coexistence to 40Mhz only Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
"What FW version is loaded?"
Modem is currently running V2.1.5.2.
"What channels are you using on 2.4 and 5Ghz?"
2.4 was running on 7 and 5 was on 36, I will update to 1 and 40 and see if there are any changes.
"Set 20/40Mhz Coexistence to 40Mhz only"
Just to make sure I'm understanding this correctly, in order to do this would I just need to untick the 20/40 Coexistence, as my advanced page does not appear to show a "40Mhz only" option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update @FURRYe38
I have changed the 2.4 and 5Ghz from Auto detect to specifically channels 1 and 40, also toggled the 20/40Mhz. After doing these changes the issue returned right away so I power cycled my iPhone as well as the CAX80, but still encountered the issue.
I enabled the 20/40Mhz again, and that seemed to resolve the issue for over an hour. However, as soon as I moved the iPhone from the room the CAX80 is physically located, the issue resurfaced.
Additionally, I discovered our iPad is also now encountering the same issue as the iPhones. All other connected devices remain unaffected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried disabling AX mode on both radios?
Maybe try disabling Smart Connect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Appreciate the response and suggestions, unfortunately the seems to still be persisting.
Additionally, it appears the speed issues I had mentioned in my previous post with my Xbox consoles has also returned.
At this point this leads me to believe this issue is with the hardware or FW with the CAX80 itself. I'm going to attempt a factory reset of the modem and start over from square one, if all else fails at this point the device will be returned to the retailer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to try channel 1 and 40.
Set 20/40Mhz coexistence to 40Mhz only.
Enable WMM, Beamforming and MIMO as well.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
- Mark as New
- Bookmark
- Subscribe
- Permalink
After completing a reset of the modem and starting over fresh, I verified the firmware version and it remains V2.1.5.2, I also manually assigned the Wi-Fi to channels 1 and 40.
I was able to verify Beamforming and MIMO are both enabled. However, I'm not actually seeing an option for WMM / "QoS" in my advanced settings any where.
For the moment the issue appears to be resolved with the mobile devices under the new SSID.
Connection status:
Cable Diagnostic | ||
Status: Good | ||
Internet Access: Green | ||
Downstream Status: Green | ||
Upstream Status: Green | ||
Event log since reset:
Thu Jan 12 13:20:54 2023 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:44 2023 | Warning (5) | Dynamic Range Window violation |
Thu Jan 12 13:08:44 2023 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:40 2023 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:32 2023 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:32 2023 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:32 2023 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 12 13:08:32 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:02:59 1970 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
Thu Jan 1 00:02:53 1970 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:7e:95:40:f9:61;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:02:39 1970 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:26 1970 | Warning (5) | Lost MDD Timeout;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan 1 00:01:18 1970 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=34:98:b5:cf:dd:19;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see some Criticals and Errors that the ISP should review and help resolve.
Can you please port the bottom portion of the Cable Connections status page as well.
