Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Modem/Router speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-22
11:15 AM
2023-08-22
11:15 AM
Modem/Router speed
Activated Nighthawk AC1900 WiFi cable router with voice (C7100V) in March 2023 with no trouble until recently. Connection issues occurred last two Sunday overnites. Issue disappeared on Tuesday but returned following Sunday. Provider diagnoses issue as modem not capable of handling speed. Unit is 3.0 and they say I need 3.1. They also installed their company owned modem again temporarily. Does this make sense? Thank you.
Message 1 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-22
11:18 AM
2023-08-22
11:18 AM
Re: Modem/Router speed
Yes. The 7100 is a older DOCSIS 3.0 and doesn't support 3.1. I recommend you get into a new gateway modem or go with separate modem and external wifi router configuration.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-22
11:39 AM
2023-08-22
11:39 AM
Thank you. Would it be worth reducing internet speed slightly to accommodate this model? Just two people in the house and I’ve only had it 6 months.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-08-22
12:18 PM
2023-08-22
12:18 PM
if that's something the ISP supports, sure. 3.0 was mostly good up to around 800Mpbs max. Never really supported 1Gb and ISPs not mostly required a 3.1 modem to support 1Gb fully now days. If you can get by with less, then go for it.
At some point the ISP may stop supporting 3.0 modems and will required you to upgrade to 3.1 something.
Message 4 of 4
Announcements
