Orbi WiFi 7 RBE973
Reply
NETGEAR AC1750 - 2.4 radio not broadcasting
JCM1313
Was working fine, now suddenly cannot see the network name for the 2.4 GHz radio. I've tried turning the radio on/off both manually and via logging into the router on an ethernet connection. All the settings seem to be correct, as they were prior to this issue. But still no luck. Any suggestions? Thanks!
Message 1 of 4
Guru
Re: NETGEAR AC1750 - 2.4 radio not broadcasting
Try changing the ssid name?
Or checking to see if SSID broadcast was enabled?
Message 2 of 4
JCM1313
Yup, tried both a number if times. Tried changing channel also. Nothing seems to work....
Message 3 of 4
Guru
Tried a factory reset and reinstall?
push and hold reset for 7-15 seconds while its powered on?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 522 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
