Orbi WiFi 7 RBE973
Reply
NO WIFI
westase1
Follower
NO WIFI
Let me start off by saying I don't know much about computers. I have checked all my cables and have determined that when the WIFI quits the cablr coming in is still OK. I can disconnect power from the modum for several hours and it will then work. If I power dowm for 2 or 3 minutes it doesn't help. Added  a external fan because I thought it might be a heay related issue and that didn't help. I only have amazon fire TV, Lap top , and a phone. Usually when it quits there is only 1 device being used. I can't find anywhere the length of warranty. This unit was purchased 5/15/2018 and has been a probiem for several weeks now.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: NO WIFI
Has a factory reset been performed and setup from scratch?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 370 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
