- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Portforwarding Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, i have a Netgear CG4500BD and a nighthawk.
Im having issues at playing a game online with my friends (Minecraft, hosting a server)
it seems as if the CG4500 is the "host" if you will. It has all the lines running into it, while there is a ethernet cable running from it into the nighthawk, so I guess both are in play. But when I look into the setting of the CG4500BD it says Modem Status. I'm relatively new to this so sorry if there is any confusion.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello cGdeadly
You would need to forward the ports on the CG4500BD for the Server and also make sure you have your Nighthawk router set to be a access point which you can get to in Advanced-Advanced setup-Wireless settings then select AP mode.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello cGdeadly
DarrenM
