- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk CAX80 VLAN Compatability
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all!
Thank you first of all for any help offered.
I want to connect the CAX80 WAN port directly to a VLAN port on a Cisco switch.
What I'm trying to do is connect a WAN port from a Modem to the CAX80 that is on a different floor through the switch.
Modem_WAN ==> Cisco Switch_VLAN_Port1 ==> CAX80_WAN
Thanks again!
TechMiner
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk CAX80 VLAN Compatability
The CAX80 doesn't have a ethernet WAN port. The CAX80 requires the use of the RG6 cable coax signal connection for it to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wow,
Thank you for this amazingly quick reply FURRYe38!
So the LAN (Multi-Gig 2.5/1G) is used for what sir?
TechMiner.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just for that, a LAN port.
The CAX80 needs a coaxial input or it goes into a boot loop.
If you already have services coming in, you don't need a modem/router combo device. You just need a router.
