Orbi WiFi 7 RBE973
Reply
Should I use CM1150v with Orbi RBR50 or Xfi wifi 6?
Van94603
Follower
I was just given used CM1150v modem with a Orbi RBR50 router with a RBS50 Satellite included. I currently have a rented Xfi gateway wifi 6 (modem/router combo). Not sure which is better overall
Message 1 of 2
Re: Should I use CM1150v with Orbi RBR50 or Xfi wifi 6?
Best is what suits you. If the modem and Orbi work, then you can save yourself the cost of the rental.
Modem/router combinations generally have fewer features than standalone devices. And with a cable modem/router you are probably stuck with the original firmware. Updates are down to the ISP.
Orbi is generally better for wifi than you'll find on a modem/router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 300 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
