- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ac1200 c6220 running hot
- Mark as New
- Bookmark
- Subscribe
- Permalink
If this has already been posted, I apologize. Just hooked up my C6220 last week and works great. I have noticed that the coax connector at the modem seems unusually hot. Top of modem also hot. Is this normal?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure the modem is in a open place with airflow but if it gets way to hot to the touch I would contact support.
DarrenM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ac1200 c6220 running hot
I have a new (end of June, 2018) Netgear modem router that is running very hot. It is in an open space with air circulating around it. Is this normal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you feel it is to hot I suggest contacting support they will be able to replace the unit if needed.
https://www.netgear.com/support/contact.aspx
DarrenM
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
