Orbi WiFi 7 RBE973
Reply
acces plex+dlma
gnanard
acces plex+dlma
Bonjour
j'ais installe un hub GS308T pour avoir l'agregation sur mon synology ds220+
mon probleme c'est que depuis je ne voies plus ma biblioteque de films dans plex
et je n'ais plus acces egalement en DLMA
ceci sur ma tele LG
merci de votre aide car cela doit etre un probleme de configuaration car quand je rebranche mon ancien hub ethernet je n'ais pas de soucis mais il ne fait pas l'integration
merci d'avance
Model: GS308T|NETGEAR® S350 Series 8-Port Gigabit Ethernet Smart Managed Pro Switch
Message 1 of 3
Guru
Re: acces plex+dlma
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Smart-Plus-and-Smart-Pro-Managed/bd-p/business-smart-plus-click-swi...
Thank you.
Message 2 of 3
gnanard
Re: acces plex+dlma
Hello
I installed a GS308T hub to have aggregation on my synology ds220+
my problem is that since then I no longer see my library of films in plex
and I no longer have access also in DLMA
this on my lg tv
thank you for your help because it must be a configuration problem because when I reconnect my old ethernet hub I have no worries but it does not integrate
thanks in advance
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 536 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
