Orbi WiFi 7 RBE973
Reply
my problem is the power is a solid Amber
RichardHG706
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 3
RichardHG706
Re: my problem is the power is a solid Amber
My router was having low internet speeds so I turned it off and after a few minutes I turned it back on. Thats when the problem start. The power light is a solid amber and the rest of the lights are a solid green. I tried reseting to factory settings but that did not work. I turned it off and let it cool. Still having the same issue.
Message 2 of 3
Guru
Contact NG support and file a support ticket:
https://www.netgear.com/support/#
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 314 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
