- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best Home Wifi Solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I'm looking for a router which I can connect multiple devices to (up to 10), which can support HD streaming and internet.. the thing is that i'm looking for 4G mobile data soltion rather than cable / fibre / ADSL.
I don't want to pay line rental anymore and I don't have any options for fibure to the home and if I weren't paying line rental, I'd be able to get much better speeds but sacrifice on some data allowance.
In times of old, I would have looked at small business cisco routers which have USB ports compatible with 4G dongles but I can't seem to find this info on any of the high spec night hawk routers.
Am I right in thinking that I'd probably need to purchase a 4G Gateway of sorts which i'd connect with ethernet cable into a router?
If anyone has any suggestions, I'm all ears 🙂
Thanks folks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best Home Wifi Solution
Hello Rico
You may want to check out this mobile modem and then you can use any router you want to.
http://www.netgear.com.au/home/products/mobile-broadband/lte-modems/LB2120.aspx
DarrenM
