- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
M2 connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
M2 connection
I'm trying to connect my M2 via ethernet cable to another router and/or powered switch to connect about three devices (including an ip camera) but it won't work. Is there a setting I need to enable or change please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M2 connection
@jstvj1 wrote:
Hi
This is a case of piling router on router. That can cause chaos.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
In the case of the M2 (probably the MR2100), the best option may depend on this router. It might work to put that in access point mode.
Or someone here may have worked out how to "bridge" the MR2100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M2 connection
By M2 I did mean MR2100.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M2 connection
Sorry about that.
Your MR2100 is a modem/router that manages all the traffic on your local network. A bit like a traffic cop.
If you add another router, then you end up with two traffic cops. Stand back and watch everything grind to a halt.
One way around that is to turn off the router bit of one of those devices. Your MR2100 or the second one you mentioned.
Some modem/routers have a simple built-in setting that does the job for you. (It often goes under the label "bridge mode".) Then your second router plays the good cop role.
I can't see an easy way to do that on the MR2100.
Another way to keep the traffic flowing is to turn off the router bit of the second router and plug it into the first modem/router. Your MR2100, which then becomes the good cop.
Then you can use the second router as what they call a wireless access point (AP). Most of the routers I have played with make it easy to turn off the router bit of the second router
It really isn't that complicated. Unfortunately, it can be impossible to work out what is going without a little bit of head scratching.
Maybe there's a neighbourhood nerd who likes playing with these things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: M2 connection
