- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mobile Wi-Fi solution
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, living in country area (Ontario,CA) I'm looking for a solution for having fast speed internet at home.
I came to the conclusion to go for a Mobile Wi-Fi Hotspots device that should support Advanced LTE, but also because I have to cover about 4000 sq.ft. I want to use Mesh WIFI devices.
Is it possible to combine both systems? For example, the Nighthawk M1 Mr1100 G/M²/LTE and connect the Orbi WiFi System (RBK50) AC3000 ?
I hope it is possible.
Do you also have other suggestions of architecture or models?
thank you,
Vince
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mobile Wi-Fi solution
Absolutlely!!! this is a great combination. You can plug the M1's Ethernet port directly into the Orbi and add satelites as you need. Another option is to use the LB1120 which is a cheaper option than the M1 but it has very limited band support. So you will need to make sure that the LB1120 will work in your area, the M1 supports many more bands.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
