Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Netgear Nighthawk MR1100 drops in and out even after adding a 7dBi Gain antennae
robyn2117
Follower
I live 48km from Perth at Serpentine on the coast side of the Darling Ranges.. My ADSL2  connection deteriorated over the past 5 years and drifted between 0.4mbps and 1.6mbps despite numerous visits from Telstra who grumbled it was poor connectors at each node  and that I lived 4 km from the exchange. As I had no problems with my Telstra mobile phone connection on my i phone 8 (although it was only 2 bars)  I would give mobile broadband a go with Telstra. My Nighthawk MR1100 router arrived on 28 December and is performing even worse drifting in and out of connection. I did an Ookla speed test and it sits around 0.4mbps...worse than my ADSL. I have had the router checked by Telstra at a Telstra shop and nothing wrong with it....was reading 38mbps. They suggested  I purchase an antennae from JCar.  I have attached a $69 Digitech 7dBi Gain 3G &4G antennae and initially it registered 28mbps but  an hour later and it is down to 0.1mbps. Has anyone got any suggestions as we can't even do home banking and I am trying to run a business from home.Could someone also advise me how I can do a speed test through Netgear?
Model: MR1100|NIGHTHAWK M1
Message 1 of 2
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Netgear Nighthawk MR1100 drops in and out even after adding a 7dBi Gain antennae
Hi @robyn2117
Please check the signal quality using the Diagnostic screen found under Settings > Nighthawk M1 Status > Diagnostics.
RSRP : typical range is around -44dbm (good) to -140dbm(bad).
RSRQ : typical range is -19.5dB(bad) to -3dB (good).
You can also move the device to a location/area with clear view of the sky.
Blanca
Community Team
Message 2 of 2
All Replies
Blanca_O
NETGEAR Moderator
Hi @robyn2117
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2050 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
