× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1 connect to LAN (ethernet cable)
Piet200
Follower
I am looking for a setup to use the M1 mobile router as a backup of my internet on my lan.
Does anyone know if this is possible?
It does look like that I can hook it up to my wifi network and make it function as a backup in that way. but not when I connect it to my network using the lan port.
I tried the 'IP passthrough' setting, but that doesn't work at all.
Any suggestion is welcome.
Message 1 of 3
JohnPeng
NETGEAR Expert
Re: Nighthawk M1 connect to LAN (ethernet cable)
Try WiFi OR ETHERNET offloading feature and see whether that is what you need.
Thanks
Message 2 of 3
mli
Tutor
Tutor
If you want to do this seamlessly, you want to look into routers with failover or load-balancing functionality.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 763 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
