derek42
Mar 29, 2021Aspirant
Nighthawk M1 no WiFi Offloading
This subject has been raised before, but I cant find a suitable answer that will answer my problem.
The M1 will offload to to a WiFi router by ethernet but when I try to offload by WiFi to the same router it wont connect.
Netgear ip 192.168.1.1
WiFi router ip
LAN TCP/IP Setuphelp
IP Address: . . .192.168.01
IP Subnet Mask: 255.255.255.255.0
Use Router as DHCP Serverhelp
Starting IP Address: . . .192.168.0.2
Ending IP Address: . . .192.168.0.254
No RepliesBe the first to reply
