- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M1 roaming won't work APN settings Portugal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi hoope someone can help . I am getting extremely cross. Trying tio get roaming working in Portugal but need APN settings for Portugal carrier MEO , Nos , perhaps vodaphone. Sim works in a phone but router no . can even get intoi the mobile app now.
Suggestions of what to do where to look would be appreciated as it is ruining my trip Nighthawk M1
Thanks
joyce
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M1 roaming won't work APN settings Portugal
On the APN setting page, please check Roaming data to enable it. Then the device will be able to connect to roaming network automatically.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi thanks for response unfortiunately did not work with this sim. Another sim did work. My internet supplier seems incapable of providing me with APN settings and I don't know where to find them for Bouyages France
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your APN setting is the same as what you used in your home network, but data connection still can not be set up after you enable Roaming data checkbox, that means your SIM plan may not have roaming data enabled. Please check your carrier.
If you buy a local SIM card, you can ask the vendor what APN to set.
Thanks
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
