× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M6 Pro MR6450 Flaky Internet over WiFi
mihai02t
Follower
I am using a Nighthawk M6 Pro (model number MR6450, FW version NTGX65_12.01.54.00) connected to an EE network over 5G, in performance mode with battery out and original power supply. The WiFi is configured as Dual mode 2.4+5GHz (WiFi 6, not 6E), the SSIDs are set to have the same name. It used to work perfectly fine for a month, then I started having internet issues when using WiFi. The display shows 4 bars and 5G, a speed test showing 300Mbps+ at times. However, there are numerous times when the internet connection becomes flaky and is dropping, for minutes at a time. Then it starts working again for a few minutes (albeit slow internet connection), then it drops again. Both WiFi bands are set to auto and checked with a WiFi analyzer app that there are no big interferences in the area. The issue is non-existent when I am plugged to the Ethernet port. Therefore, I suspect something is wrong with the WiFi and not with the 5G connection. Has this happened to anybody before and is there a known issue regarding this? Thank you!
Message 1 of 1
Discussion stats
  • 0 replies
  • 243 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi 770 Series
