Orbi WiFi 7 RBE973
Reply
Can i unplug my cm700 router ?
Lansdon
Follower
Doing some painting around the house. If I unplug the router, will I need to activate everything again after I put it back on ?
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Can i unplug my cm700 router ?
> [...] If I unplug the router, will I need to activate everything again
   Shouldn't be a problem.  Many of these things don't even have a
button in the user interface to let you do an orderly shutdown.
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Discussion stats
  • 1 reply
  • 613 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
