- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D7000 Adsl stops broadcasting WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in uk so router is vdsl adsl no separate modem.
After about a day the WiFi stops broadcasting. I tried splitting the 2/5 and disabling guest but it stops and a reboot brings it back up again.
Has anyone see this before and has a long term fix then rebooting the router every day?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D7000 Adsl stops broadcasting WiFi
Is this a new device? What version firmware, give version number please? Is it a v1 or v2 device? I believe this has been reported by other users of this device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/x/x/m-p/1728228
> [...] Look at the product label. Firmware version?
Still wondering.
[...] D7000-200UKS
As its product label should say, that's a D7000v2. Firmware version?
> [...] After about a day the WiFi stops broadcasting. [...]
Determined how, exactly? Both 2.4GHz and 5GHz?
Providing no useful information in a more appropriate place is not a
big improvement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
V1.0.0.51_1.0.1
It’s stops broadcasting as you can not see the ssid from any device. Both 2/5 and guest .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is newer firmware available for the D7000v2 here
https://www.netgear.com/support/product/D7000v2.aspx#download
If that doesn't fix it, I'd consider returning it for a different brand device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> There is newer firmware available for the D7000v2 here [...]
Or, more generally, Visit http://netgear.com/support , put in your
model number, and look for Downloads. (For older versions, under
Firmware and Software Downloads, look for "View Previous Versions".)
Find the kit(s). Download the kit(s) you want. Read the "Release
Notes" file for instructions.
But I might not expect much from V1.0.0.53:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok so I upgraded the firmware and still and issue. I unplugged everything else but after about a day it needs rebooted.
I was using a BTHomeHub6 and on saturday I went back to it as I wanted to watch the Rugby and didnt want anything to mess it up.
Its a bit annoying spening 150 odd quid for a lemon! My firend has the non ADSL version and likes his so thought it would be a good purchase.
At this rate I am thinking of RMA'ing it and trying a good onld trusty Draytek.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd go with the RMA option since you've tried other remedies. I don't believe Netgear will provide any additional support for that version device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now after a half a day (and to be honest not much use) the 5ghz signal will disappear and when you try to connect to the 2.4 it just keeps asking for a password and saying t is wrong when it’s not.
Again a reboot sorts it.
