Orbi WiFi 7 RBE973
Reply
DGND3700v2 with printer connected to USB after installing Windows 10
SDlask
After installing Windows 10, printer will not print unless directly connected to laptop.  What is the solution?
Message 1 of 5
w3wilkes
Prodigy
Re: DGND3700v2 with printer connected to USB after installing Windows 10
What kind of printer? With a couple of HP All-In-Ones I've had to completely uninstall and reinstall the printers after installing W10 to get the printers back.
Message 2 of 5
SDlask
The printer is a HP Deskjet F4440 all-in-one.
I wondered if I would have to reinstall the printer!!
Message 3 of 5
w3wilkes
Prodigy
After you do the reinstall check that all is well. Then restart and make sure the printer is still installed. If the printer disappears with a system restart I found that the service called "HP CUE DeviceDiscovery Service" somehow causes the printer to disappear. Just go into Services and disable this service and it should correct the problem of the printer disappearing on reboot.
Message 4 of 5
SDlask
Thanks for the input.  I was able to get the printer working again.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3449 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
