Orbi WiFi 7 RBE973
Reply
LAN 1 Port dead on Netgear Nighthawk D7000 AC1900.
Phantomas
It's my first Netgear device and i discovered this problem.
LAN 1 port it's dead when i connect a ethernet cable. Work only the rest 2-3-4. The device it's brand new. Any help ?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Guru
Re: LAN 1 Port dead on Netgear Nighthawk D7000 AC1900.
You should post this here under modems for this model:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Message 2 of 6
ElaineM
NETGEAR Employee Retired
Just moved it to the appropriate board.
Message 3 of 6
Guru
Return the unit for another new one.
Message 4 of 6
Phantomas
Return in NETGEAR ? It's not posibly to fix LAN 1 port ?
Message 5 of 6
Guru
Only other thing to check is the pins inside the jack to make sure they are not damaged or touching each other. If swapping cables doesnt' do anything this it's a HW issue and needs to be replaced. Nothing else can be done.
Good Luck.
Message 6 of 6
Discussion stats
  • 5 replies
  • 3812 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
