- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NETGEAR D6400 Cannot update from 1.0.0.74 to newer versions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I can't update the firmware of my D6400. I tried manually uploading the file (for the latest 1.0.0.114 and also for 1.0.0.80 as a gradual update), also tried tftp, but nothing seems to work. Any suggestions?
The loading starts, but then it interrupts and nothing happens.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NETGEAR D6400 Cannot update from 1.0.0.74 to newer versions
what error does tftp give you when you try?
Are you trying over a hardwired connection?
Have you tried a different pc/laptop?
did you try downgrading a version (in case its a version issue) and then upgrading?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
When doing tftp, the connection seems to be interrupted for some reason, however I can still use internet without any issue.
I guess I can give you a screenshot later to show you.
I'm trying with a hardwired connection yes, I haven't tried with other computers since I heard that updating over wifi was not recommended, but I can do that!
I tried downgrading as well, but did not work..
- Mark as New
- Bookmark
- Subscribe
- Permalink
are you able to access the router through the gui? (through the browser)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I can see everything on the website
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not so much a website. It is on your modem/router. Hence the graphical user interface (GUI) tag.
If you can get into that, TFTP should not be necessary.
What errors do you get when you try this?
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Comments like "didn't work" provide no diagnostic information. There's usually some sort of error message that helps us to home in on the cause of the problem.
I assume that you unzipped the firmware. Believe or not we see a trickle of people here who somehow missed that vital step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I did unzip the file, followed the steps multiple times, but the file upload just stops at 1/4 of the loading.
This is the error I get (I translated it to English)
The page at the address http://192.168.0.1/upgrade_check.cgi?id=8a59908b322d4a178b426d6800e6d59ef8dd089e0a84761ad8c9922e4c65... may be temporarily unavailable or it has been permanently moved to a new address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you following these instructions?
How to update firmware on your NETGEAR product | Answer | NETGEAR Support
And
Make sure that the unzipped file is somewhere that you can get at it easily. Try moving it to somewhere else on the PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try an intermediate version.
74 to 114 is a huge leap. There have been times when the changes are so severe that the hardware can;t take it.
I have had a D6400 since they came out. I can't remember if there were any big jumps like that, but there is no harm in trying.
Go for something in the middle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
Thanks. However, yes I followed those instructions, as I have already mentioned. Also already said in the first post that I tried gradual updates too.
