- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear D6300 dual band - fail to connect to iphone 4 (IOS 7.2.1)
- Mark as New
- Bookmark
- Subscribe
- Permalink
iphone 4 (IOS 7.2.1) failed to connect to D6300 router today for the first time. Router now showing as 'netgearxxx-5g' rather than previously as 'netgearxxx'. I have not updated anything though the router may have overnight. No issues with other apple product (notebook, iphone 6).
iphone 4 can 'see' wifi network, but not able to connect - all router settings blank. Performed Apple 'Reset Network Settings' without success.
any ideas?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Saves us buying a new iPhone straight away.
Router supports both 2.4 & 5g, but doesn't switch between automatically.
This thread may now be closed. Thanks
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear D6300 dual band - fail to connect to iphone 4 (IOS 7.2.1)
You should verify that your 2.4Ghz radio didn't get turned off somehow. If the device shows the 2.4Ghz radio active and other devices can see and connect to the 2.4Ghz radio you should try rebooting both the phone and router. If you still have the problem and no devices can connect to the 2.4Ghz band radio you may have a defective wifi router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
