- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk X4S D7800 All ports open
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ran ShieldsUp on my setup recently https://www.grc.com/shieldsup
And it reveals that every single port known to man is OPEN.
d7800 firmware version 1.0.1.16 (latest)
I have tried everything to secure the dam thing but nothing seems to work
What can I do? Need help please
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk X4S D7800 All ports open
Hello Driftyz
All ports should be closed untill you open them if needed I am not sure why your tool is telling you that they are all open. Try this link and pick one of those ports and see if its still open
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried that sight and any port I try replys with SUCCESS.
I have NAT set to secured. It is not by any means
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the WAN options set to default. Which means it should block port scanning. Mine does not. I have toggled the option on/off to see if any difference and there is not. However the block ping option works as decribed. Just not the firewall. Does this mean the DOS protection not work either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Driftyz
I would suggest contacting support they will be able to help troubleshoot the issue and replace the unit if needed if it is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
