- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
why is my new CM500 modem more than 50% slower than my comcast Arris tg862.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: why is my new CM500 modem more than 50% slower than my comcast Arris tg862.
Hello hunkemd
Can you give more detail on the issue you are having with the CM500.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
DarrenM,
I have Xfinity cable. I did a speed test before I swaped modems and the (Xfinity) Arris TG862 was at 89 MPS download and 12 MPS upload. When I installed the CM500 I did several more speed tests and the best I could get was 36MPS download and 8 MPS upload. I have reinstalled the Arris (Xfinity) modem I was un happy with the performance of the CM500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello hunkemd
Did you check the levels in the settings of the CM500 to see if anything was off when you had it hooked up?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I did not check any levels. There were no troubleshooting tips for slow speed. What levels do I need to check and what are the acceptable levels?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello hunkemd
You will need to log into the modem by going to 192.168.0.1 or 192.168.100.1 then login with admin/password
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
DarrenM
