Orbi WiFi 7 RBE973
Reply
Genie login error
DrGori88
Tutor
Genie login error
Can not login to router using admin name and password as directed. Frustrating
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 10
Accepted Solutions
DrGori88
Tutor
Re: Genie login error
Thanks . I did also try nighthawk app and it does not support C6220
Message 9 of 10
All Replies
schumaku
Guru
Afraid, I'm confused.
On one hand https://www.netgear.com/home/products/networking/cable-modems-routers/C6220.aspx#tabs-EaseofUse and the https://www.netgear.com/images/datasheet/networking/CableModems/C6220.pdf says "NETGEAR GENIE® APP—Personal dashboard to monitor, control & repair your home network" (I want to see the repair oh Netgear!)
On the other hand https://kb.netgear.com/24686/Which-NETGEAR-home-router-models-can-I-manage-using-the-NETGEAR-genie-a... does not list the C6220.
@ChristineT  @Christian_R  Netgear at it's best again - some teeth in the gear must be broken. No, the C6220 isn't a new product, the Data Sheet is from 2017.  Please clarify what is going on here.
Message 2 of 10
DrGori88
Tutor
Thanks for your help. Hope someone from support can iron this out for me.
Message 3 of 10
Thor_Keck
Help
I was forced To move to the Nighthawk app and now it won’t login
Did forgot password cycle twice the error says it is “ an error has occurred“
Please hurry with this
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 4 of 10
Rather than dashing down blind alleys and trying to beat Netgear around the head, it might be quicker if we start with the basics.
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
There is support for this device at the end of this link:
>>>C6220 | Product | Support | NETGEAR<<<
I see no sign that the C6220 supports any of these various apps. The manual does talk of the genie, but it is not clear which one it refers to.
To get the desktop  genie for your operating system, start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
What are you trying to achieve with the genie? That would help to pin down the right tool to use.
Have you tried accessing the modem router in the usual way, with the graphical user interface (GUI) and the browser? This is usually the most versatile way in.
If that fails, try this:
If you cannot login to your router | Answer | NETGEAR Support
Message 5 of 10
You might find it quicker if, as per the "terms of service" of this place, you did not hijack someone else's issue and started your own discussion in the right section for your hardware and with more details.
The R8000P is a completely different animal from the C6220 that @DrGori88 is trying to fix.
While we are at it, the Nighthawk app is not the same as the genie.
Message 6 of 10
schumaku
Guru
@Thor_Keck wrote:
I was forced To move to the Nighthawk app and now it won’t login Did forgot password cycle twice the error says it is “ an error has occurred“
Here you find the Nighthawk App community section - it might already contain the answer to the problem you hit.
Message 7 of 10
DrGori88
Tutor
Thanks, I did try browser to enter and did not work as well.
Message 8 of 10
DrGori88
Tutor
Message 9 of 10
DrGori88
Tutor
Problem SOLVED!!!! Returning unit back to place of purchase
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 4925 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
