Orbi WiFi 7 RBE973
Reply
WiFi Password Reset
Leach28
Follower
WiFi Password Reset
I have always had the same password. Now I can’t log into my WiFi. I can’t even change the password because it tells me I don’t have the correct one. What do I do? Is it possible it got hacked somehow? I am not vet computer savvy. Please help
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Password
Hi @Leach28, welcome to the community! If you have a device that is already connected to the WiFi then you can use that to login to the router's UI and check for the WiFi password. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/980
http://kb.netgear.com/app/answers/detail/a_id/24096
If that does not work, then a factory reset will be an option.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Re: Password
Dexter
Message 2 of 3
DexterJB
NETGEAR Moderator
Re: Password
Hi @Leach28, were you able to sort this out?
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 6963 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
