- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
HOW MANY VLANS ON A FIBER TRUNK OF A M4250: ONLU SEEING DATA NOT AUDIO DANTE AND DATA
- Mark as New
- Bookmark
- Subscribe
- Permalink
I might be missing something but I'm not able to get the Dante Audio signal data down the fiber port sharing with Data; data is fine, just no Dante Signal. Under port configuration it shows only data on the Fiber
VLAN 1 is Data VLAN 20 is Dante primary, Fiber port is set to Auto Trunk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: HOW MANY VLANS ON A FIBER TRUNK OF A M4250: ONLU SEEING DATA NOT AUDIO DANTE AND DATA
Hi @Nils-GSR ,
Something misconfigured I'm sure - if the port is Auto-Trunk it means all VLANs are going through - but it also means you are going to another M4250 switch, right?
Please make sure you are running the latest firmware (M4250 FW); also if you have several switches, you can follow our application notes with very detailed how-to's here: AV over IP Technical Guides - NETGEAR
If the problem persists, don't worry, a ProAV Design System Engineer will help you: email us at ProAVDesign@netgear.com
Thank you,
Laurent
- Mark as New
- Bookmark
- Subscribe
- Permalink
Left VLAN 1 and passed all of my data traffic there, set up a VLAN for Dante then configured the Dante card, and it worked. Very Cool, thank you.
Up until I tried to add another static data VLAN profile to separate the two data environments (Netgear default and Audio Architect control).
That addition results in a "Add Interface IP error"?
VLAN 1: Static; IP=XXX.XXX.10.XXX DHCP OFF; success
VLAN 20 Static IP=XXX.XXX.20.XXX; DHCP ON; success
VLAN 50 Static IP=XXX.XXX.50.XXX; DHCP OFF; Add Interface IP error
