Orbi WiFi 7 RBE973
Reply
m4250 fan noise
AHYA
m4250 fan noise
Hello
After updating the m4250 firmware a few days ago, the fan continues to spin intermittently even though the temperature is between 32 and 33 degrees.
How do I solve this? It is very uncomfortable because it is noisy and disturbs the music appreciation.
And is there any way to turn off the led?
Message 1 of 4
JeraldM
NETGEAR Employee Retired
Re: m4250 fan noise
Hi @AHYA,
Welcome to the community!
You should be able to manually turn the fans off, please see page 61 of the user manual here
JeraldM
NETGEAR Community Team
Message 2 of 4
AHYA
Re: m4250 fan noise
Hello
Of course, I set the fan-off setting.
The fan temperature sensor is 32 degrees, but it keeps spinning.
When listening to music, it is noisy because of the noise of m4250, so I get in the way a lot.
Message 3 of 4
JeraldM
Re: m4250 fan noise
Hi @AHYA,
We suggest contacting support here for further assistance. This can either be an issue with the device or maybe a certain threshold is exceeded (PoE budget or traffic load in your case).
JeraldM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 931 views
  • 0 kudos
  • 2 in conversation
Announcements
