Orbi WiFi 7 RBE973
Reply
Armor Vulnerability Scans Constant Notifications
LeeH21
Tutor
I just started trying the Armor and I am getting constant notifications on device vunerability scans with no issues.  I thought it might just need to scan each device once but it's scanning them over and over.  I would WANT to be notified if it found something but I don't need constant notifications that there are no issues.  Is there a way to set the notifications you receive to only be with issues?  My phone is literaly going off every 3 min or so with a new scan.
Message 1 of 3
Accepted Solutions
LeeH21
Tutor
Re: Armor Vulnerability Scans Constant Notifications
Never mind.  After about 4 hours it stopped and only goes off when something new connects.  I guess I just didn't give it enough time to get caught up. 🙂
Message 2 of 3
All Replies
LeeH21
Tutor
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hi LeeH21,
Thanks for providing an update on your post as it may possibly help others in the future.
Christian
Message 3 of 3
Discussion stats
  • 2 replies
  • 3470 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
