× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN31600 OS
m8ken
Tutor
RN31600 OS
Hello All,
I picked up today a RN316 (6 Bay NAS).
It works fine but has OS 4.2.31 on it.
I believe that it is meant to be able to have OS 6.x.y on it.
I havent been able to install OS 6 and when I boot it displays
"Legacy Boot Mode RAIDIATOR 4.2.31" on the screen.
Should I try USB Recovery with the OS6 on it???
Thanks
Mark
Message 1 of 9
microchip8
Master
Re: RN31600 OS
Wrong forum. Go to the Storage/NAS forum
You're posting in the Nighthawk routers forum.
Message 2 of 9
Guru
Re: RN31600 OS
Does the front panel look like this?
Message 3 of 9
m8ken
Tutor
Re: RN31600 OS
Yep.
Thats the one.
Regards
MArk
Message 4 of 9
m8ken
Tutor
Re: RN31600 OS
sorry mate.  didnt realize.
Message 5 of 9
Guru
Re: RN31600 OS
@m8ken wrote:
Thats the one.
Odd that someone downgraded it to 4.2.31 - not something I'd seen before.
An OS recovery is probably the best path (using the directions for OS-6 systems).
Message 6 of 9
mdgm
Virtuoso
Re: RN31600 OS
Booting into RAIDiator-x86 4.2.31 would mean the previous owner put disks from a legacy x86 unit into the RN316 to recover data off the disks. A factory default (wipes all data, settings, everything) using the boot menu should be enough to put OS6 onto the disks.
Message 7 of 9
Guru
Re: RN31600 OS
Thx -  I'd overlooked that possibility, and of course a factory default is the right way to resolve it.
Message 8 of 9
m8ken
Tutor
Re: RN31600 OS
Thanks All,  factory reset worked like a charm.  running OS6 now.
Regards
Mark
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1101 views
  • 5 kudos
  • 4 in conversation
Announcements
