Orbi WiFi 7 RBE973
Reply
IMG file does not appear in USB Recovery Utility
rampage56
I have a ReadyNAS 10400 firmware v6.1.8. I have tried to upgrade it to v6.8.1 (didnt read the documentation first) So after booting, it does not boot. Only booting.... message. If Im going to use USB recovery, what firmware version I shoud use? 6.2.5 / 6.3.5 or 6.8.1? Another problem with the utility, it cannot find the .img fileUntitled.jpg
Is this the correct path? In the instruction, place it in the marvell folder (but theres no marvell folder)Untitled.jpg
Thanks in advance
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 2
Re: IMG file does not appear in USB Recovery Utility
You are in a section about routers.
Here is the best place to pose NAS questions:
ReadyNAS Network Storage - NETGEAR Communities
There may also be older discussions there that can help.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1089 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
