Orbi WiFi 7 RBE973
Reply
Remote Genie for D7800 not working (unable to register)
Sgeorges
My device is Netgear D7800 Modem/Router. (firmware:V1.0.1.20)
I read through this forum and found it should support  remote access thru genie. But I have trouble with enabling the remote access from genie.
I was successfully using Remote access with my previous R8000but but recently switched to D7800 for NBN.
Spent a lot of time and  followed setup procedure but couldn't register it.
In step 10, getting an error message "the registration process failed"
 I also done following:
1. Resetting the device.
2. Uninstalling and re-installing genie.(in phone & computer)
3. Tried previous versions of firmware / genie.
4. Tried from computer/ and from different android phones/tabs.
Please help. Thanks.
Message 1 of 12
DexterJB
NETGEAR Moderator
Re: Remote Genie for D7800 not working (unable to register)
Hi @Sgeorges,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 2 of 12
Sgeorges
Hi Dexter,
Thanks for your message.
Surprisingly it started working now once I tried from another Android phone again.
All good 😞
Message 3 of 12
UriahSefo
Initiate
I'm having the exact same problem. Please help
Message 4 of 12
DexterJB
NETGEAR Moderator
Hi @UriahSefo,
1. What is the model number and firmware version of your device?
2. Have you tried using another device?
3. Have you tried resetting the router?
4. Have you tried uninstalling and re-installing the app?
Dexter
Community Team
Message 5 of 12
DexterJB
NETGEAR Moderator
Hi @UriahSefo,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 6 of 12
Sgeorges
Hi Dexter,
Thanks for your follow up and sorry for the delay in replying.
I have same problem again after updating the firmware to V1.0.1.22
(FYI:  Recently tried firmware V1.0.1.24 , but no internet connection. Hence rolled back to V1.0.1.22).
Now router is working OK but no remote genie. Please advise. Thanks. George
Message 7 of 12
DexterJB
NETGEAR Moderator
Hi @Sgeorges,
Please make sure you do a factory reset after updating the firmware.
Dexter
Community Team
Message 8 of 12
Sgeorges
Hi Dexter,
As you advised I have done a full factory reset and reconfigured the modem-router. (firmware V1.0.1.22)
Modem-router is working OK for internet (NBN) connection but still not able to enable the genie remote access.
Error message is : "The genie cloud server connection failed. Try again"
Tried many time but still no success. Please advise. Thanks & regards
George.
Message 9 of 12
DexterJB
NETGEAR Moderator
Hi @Sgeorges,
Dexter
Community Team
Message 10 of 12
Sgeorges
Hi Dexter. thanks for your support. With latest firmware (V1.0.1.28) I could get the Genie  connected to the router remotely. But no devices listed under network Map. Please advise.
Thanks & Regards,
George
Model: A6210|AC1200 High Gain WiFi USB Adapter
Message 11 of 12
vipsin
Unable to turn ON remote access from Genie app.  India Technical support is pathetic, just novice guys. Getting error " NO remote access" the genie cloud server connection failed. Try again.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 12 of 12
Discussion stats
  • 11 replies
  • 4503 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
