- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk XR500 Dropping Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk XR500 Dropping Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! I had already had .10 as the starting point as I only have two managed switches and two printers assigned in there thinking that the rest of my network could stay above that since I only have one computer I use reserved and another laptop I rarely use reserved above the .10 numbers. I do have a lot of smart home devices such as plugs, light bulbs, Ring doorbells and cameras, TVs as well as various other cameras. I reserved only two computers and let the rest assign itself. I will expand that up to .50 if you think that will make a difference or if you think it could be this I just discovered below...
UPDATE: Since posting this initial post, I found out I have a lot of DoS attacks. I contacted my ISP for a new IP address because renewing my DHCP lease used to reset and give me a new IP address years ago but it seems to not be that way now. They said I had to swap out my modem. Here's some of the attacks I'm getting. Don't know what else to do except swap out my modem. Any ideas? Thanks!
These are some of the attacks:
[DoS Attack: SYN/ACK Scan] from source: 51.38.116.208, port 25565, Tuesday, November 21, 2023 15:26:20
[DoS Attack: SYN/ACK Scan] from source: 103.233.161.238, port 8080, Tuesday, November 21, 2023 15:24:12
[DoS Attack: SYN/ACK Scan] from source: 103.233.161.238, port 8080, Tuesday, November 21, 2023 15:22:40
[DumaOS] DHCP new lease allocated., Tuesday, November 21, 2023 15:20:57
[DumaOS] DHCP new event., Tuesday, November 21, 2023 15:20:57
[DoS Attack: NULL Scan] from source: 182.18.90.86, port 14814, Tuesday, November 21, 2023 14:47:14
DoS Attack: ACK Scan] from source: 150.242.182.187, port 8080, Tuesday, November 21, 2023 14:31:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear routers notoriously report DoS attacks when they're not a cause for concern and just show connections you've made/websites you've come in contact with. However, yours do show a lot of Asian IPs which I don't think you'd normally make contact with. They shouldn't cause you any issues at all, the router does have a firewall so they will be blocked. Unplugging your modem for 10 minutes may prompt a new IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Thank you. I just have over 70 devices and not all of them list what they are so I will have to figure out what they are and label them properly an assign them an IP. Maybe that will let me track any funny business with some of these Chinese light bulbs and such. Thanks again!
Now if I can only figure out why my google mail settings aren't working to email me the logs. But that's another post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's purely a Netgear feature so I'm not too sure about that, could be you need direct access to the internet so make sure the XR WAN IP is in the DMZ of your ISP modem/router and it should work then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks but not sure how to set that up. Only setting for DMZ I see is for a default DMZ server IP address. No range or anything about the ISP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
