- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
TWO XR500 for whole house coverage?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an XR500 Configured with QoS, etc. - but I have a 3,000sq Ft two story house and need more coverage. I have a hard wired connection available downstairs, can I run ANOTHER XR500 in AP mode some how to extend the network?
Or should I use a EX7000, something like that, that will take a hard wired line to extend the WiFi network? Thanks! #xr500
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: TWO XR500 for whole house coverage?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I ran a EX7700 with my XR450 in a 5000sq ft home. Worked well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you using a wired backhaul? It seems certain models don't support this function?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, EX don't support wired backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks - recommendation on which one does?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Extenders don't support wired backhaul from what I understand. Wired backhaul is mostly designed into NGs MESH systems, Orbi and Nighthawk MK.
One way to use two XRs via ethernet would be to make the 2nd one in to a AP configuration. You probably use same SSID name and password on both however wifif channels would need to be set far apart on each unit. Or use a different SSID name on the 2nd router would be recommended. Same configuration would apply to a EX extender in AP mode that would be ethernet connected to the main host router.
User | Count |
3 | |
2 | |
1 | |
1 | |
1 |
