- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XRM570 having problems with discord ever since I installed new router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel dumb. I updated my intel ethernet connection driver and its seems to be working fine now. Thank you for the reply.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XRM570 having problems with discord ever since I installed new router
What is the distance between the router and Extender? 30 feet is recommended in between XR router and EX to begin with depending upon building materials when wirelessly connected.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and EX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad that was a easy fix. Please mark your thread as solved so others will know.
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
