- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
16Mbps with R6900P (100Mbps from ISP)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, members.
I feel bad to even post this as so many similar topics have been posted and discussed. After reading through a number of postings, I decided to share my issue and seek for some advice.
I recently upgraded my internet speed from 15mbps to 100mbps (xfinity). Modem is SB6141 connected to R6900P.
I noticed that ethernet speed went up to 100 mbps measured at internet speed test page. However, my WiFi speed is consistenly at around 16 mbps wtih 5GHz. This is the same speed I used to get with the lower speed plan.
I updated the router to the latest FW (1.3.2.124) (which I don't think is the cause). Is there anything I can try to diagnose the issue? Any advice will be greatly appreciated.
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your advice.
I actually disabled Dynamic QoS on the router setting which seemed to resolve the issue. The measured speed increased from 16 mbps to 80-100 on the same speed tester.
The test was done at night time when internet traffic was low. I'll see if the speed still remains similar or at least better than the initial one.
Thanks!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 16Mbps with R6900P (100Mbps from ISP)
Have you tried disabling qos?
Or tried a simple factory reset? Maybe an old qos setting is being retained and causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear it was the simpler step to get it working!
