- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
8000P Dropping connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
guys, I have looked over the notes, they do not work for me. I keep dropping connection, moden says connected, verified with provider, shows online with them. I have to reset for it to work, 3-4 times a day. HELP PLEASE. I work from home. updated firmware. Is there a set up that is better than others?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 8000P Dropping connection
You didn't give us much to go off.
1. What firmware are you currently on?
2. What modem/gateway is it connected to?
3. What's actually happening for "dropped connections. Is it saying, "connected, no internet", is the wifi not broadcasting anymore, is it broadcasting but you can't connect, do wired devices drop, is it specifici to 2.4ghz over 5ghz? We need actual details to help, not minimal info.
4. You have to reset it? Do you mean reboot? A reset is a factory reset and new install. Did you try that option?
