Orbi WiFi 7 RBE973
Reply
AC2600 Model R7450 Unable to connect to internet. I get a secure connection but no inernet.
bob1951
Follower
Model Number R7450
Firmware Version v1.2.0.92
App Version 2.23.0.2673
Message 1 of 3
Guru
Re: AC2600 Model R7450 Unable to connect to internet. I get a secure connection but no inernet.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
Message 2 of 3
Any chance of some details about your problem?
Something about "secure connection but no internet"?
What tells you that?
If this is a connection through a Windows PC, then maybe you need to tell the PC that you are on a private network.
Windows 11:
Properties
That's just a guess based on incomplete understanding of what your problem might be.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 879 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
