JosephGallagher
May 12, 2021Follower
AX12
I have been running an AX12 router for about a year. I have multiple devices including 4 streaming televisions. In the last few weeks the router continues to looose connections with my devices. After several minutes they may reconnect or I would need to manually reconnect. Is this an issue with only this router? Is there any solution? I tend to like Netgear products, however I am thinking to replace this router with another brand to see if it solves my dilemma.
Sort By
- microchip8Master
Before tossing it, have you tried a factory reset and reconfigure from scratch?
A couple things.
1. the RAX200 was released before the AX spec was finalized. Some of its firmware comes direct from broadcoms underlying drivers.
Its responded favorably to factory resets after firmware changes. If you have issues after firmware changes, try the reset like microchip8 says.
2. because the underlying drivers are changing with some of the firmwares, the problem could always be the underlying driver. Try downgrading the firmware, factory resetting, and reinstalling. disable auto updates and see if it works better. If it doesn't, leave the update disabled until a new one comes out.
