Orbi WiFi 7 RBE973
Reply
Android OVPN Configuration File for Firestick 4K
mparsel
Tutor
Is there a single OVPN cliebt configuration file for the firestick?
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 3
Accepted Solutions
mparsel
Tutor
Re: Android OVPN Configuration File for Firestick 4K
Problem solved.  all you need to do is identify the file location in the client3 file.  (e.g. ca /download/openvpn/ca.crt, cert download/openvpn/cliernty.crt, ...)
Message 3 of 3
All Replies
mparsel
Tutor
I would like to include the CA, Cert and Key in a single configuration file.  The firestick wont read the seperate files when running client3.ovpn.
Message 2 of 3
mparsel
Tutor
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1055 views
  • 1 kudo
  • 1 in conversation
Announcements
Orbi WiFi 7
