Orbi WiFi 7 RBE973
Reply
Anywhere Access
gavinbecker
Initiate
Anywhere Access
I can't seem to find the option to turn on anywhere access anywhere in my nighthawk on my iphone. Any help is gretaly apprecieted. Every forum I've checker has said the same thing and my app is not displaying what the forums say it should be displaying.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Anywhere Access
By far not every Netgear router does support Anywhere Access. Look on How do I enable or disable Anywhere Access on my router using the Nighthawk app? for the models listed under "This article applies to:". Features not available on the router accessed by the Nightawk App will be invisible.
Message 2 of 3
All Replies
schumaku
Guru
Re: Anywhere Access
Message 2 of 3
gavinbecker
Initiate
Re: Anywhere Access
ahhh looks like my router does not support it, thank you for the help.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4357 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
