Orbi WiFi 7 RBE973
Reply
Auto Update?
HankEast
Auto Update?
Does Netgear update automatically new versions? I have a R7000 and received a notice for a firmware update. Are these not done automatically?
Message 1 of 6
Accepted Solutions
Guru
Re: Auto Update?
It checks to see if there is an update available. Does not acutally update the router unless you select Update in the UI. User interactaion is needed and recommended. A wired PC should always be used when updating FW.
Message 2 of 6
All Replies
Guru
Re: Auto Update?
Message 2 of 6
HankEast
Re: Auto Update?
Thank you. I noticed this was possible although I'm not finding the UI location. I apologize if it's obvious.
Message 3 of 6
Guru
Re: Auto Update?
Log into the routers web page and you can go to Advanced tab, Adminstration, FW update section. Maybe different on your model router. I have a R7800.
Message 4 of 6
HankEast
Re: Auto Update?
Thanks.
Message 5 of 6
Guru
Re: Auto Update?
Good Luck.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 4183 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
