- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Best Current Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Best Current Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Best Current Router
The 6700 has 5Ghz support though it's older wifi tech and limited on speed and performanced.
Something to check out would be NGs RAX series of routers or maybe a RS series.
Might start here first:
https://www.netgear.com/home/wifi/routers/
Depending on home size as well, you may check into a MESH system if you want more multi source wifi coverage:
https://www.netgear.com/home/wifi/mesh/
Start by selecting the Filter options to help you narrow down something that fits your home and networking needs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, Try something RAX, maybe a RAX50 or 80 series would work good for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JesusSaves wrote:
Hello. I’m moving into a 1 bedroom apartment. I’ve never had my own router, and the complex is recommending the NETGEAR NightHawk Smart WiFi Router (R6700)-AC1750.
How do they deliver the wifi to you?
Routers need a modem to work from. Some apartments have their own "basement" equivalent of a router. That needs some fancy configuration. Ask them if you need to do any to the R6700 to get it t to work.
If you can find one, that would be a dead cheap option that should meet most needs in a small pad.
Just another user with time on their hands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the internet service/modem is not great, even the best router will not help. I agree with @FURRYe38 though, the RAX's are good and in a small place you don't want to oversaturate your wi-fi signal with a setup that overwhelms the signal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One thing I would suggest though is future proof your setup by getting a router with some of the newer protocols such as 6E. May be a bit more expensive up front, but newer devices will be able to utilize to full effect and any future devices you buy will not be hindered by an outdated router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just FYI, that Mfr seems to be under scrutiny for nefarious things they seem to be doing.
Good luck with that.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
