GeekGirrl
Sep 08, 2016Tutor
Chromecast still not working.
Anyone have success with their Nighthawk and Chromecast yet? I still cant even see chromecast on my pc steadily. I've done many tweaks to the router per this community and google with no luck yet.
I've tried:
Changing wifi channels.
Turning off 5ghz band.
Enabling Ipv6
Disableing upnp
Lowering the mgz from 600 to 289 on 2.4
and a few others I dont remember.
Even worked with tech support at netgear. They had little clue. Said they never had this issue before with their routers. ROFLOL. Do they not read there own community issues? Seems people have had this issue for years.
Any ideas on this issue? Thanks.
I guess I fixed the issue. Only one pc was having the issue so I just had to update chrome on that pc. Simply fix that is not on any other post or even in the suggested fixes at chromecast. I guess I always expect chrome to be up to date but it wasnt. My bad. Keeping the router for now as it rocks eventhough netgear support is horrible.
Sort By
Update: I just talked with Netgear tech support and they will not assist you in setting up any device that nolonger works with your new netgear router. So I'm taking my netgear router back and buying an Asus or Linksys router. Maybe I'll have better luck with their tech support. I would advice anyone with chromecast to never buy a netgear router. Too many issues. Just google it and you will see. Good luck :)
- ElaineMNETGEAR Employee Retired
LOL, the link you attached doesnt work.
Glad that it's all working right now.
Have a great day!
