w1nterl0ng's avatar
w1nterl0ng
Connecting Work Laptop disables all other devices
When I bring my work laptop (windows 7) home and connect to the network (wired or wifi) all other devices in the house loose internet connection.  when I reun a tracert I get "unable to resolve target system name" so it must be somethign that is hyjacking the DNS.
If I disconnect the computer and reboot my router, everythign comes back online.
Any help wiould be much appreicated.
  • Hi w1nterl0ng,
    May I ask for the following information:
    - What is the Internet LED status when issue occur?
    - What is the IP address of the affected device and the work laptop when Internet stopped working?
    - Will it disconnect right away when you connect you work laptop?
    Blanca
    Community Team
  • > When I bring my work laptop (windows 7) home and connect to the
    > network (wired or wifi) all other devices in the house l[o]se internet
    > connection. [...]
       What, exactly, goes wrong on those devices?  There's more than one
    way to "l[o]se internet".  As usual, showing actual actions with their
    actual results (error messages, LED indicators, ...) can be more helpful
    than vague descriptions or interpretations.
    > [...] when I reun a tracert I get "unable to resolve target
    system name" [...]
       When you "reun a tracert" of what?  Actual command?
    > [...] so it must be somethign that is hyjacking the DNS.
       Or something else.
       Copy+paste of an "ipconfig /all" report on the laptop might be
    interesting.  If it were configured with a bad IP address, then that
    might cause some problems.
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      Hi w1nterl0ng,
      Blanca
      Community Team
      • w1nterl0ng's avatar
        w1nterl0ng
        After a few tests, reviewing the logs and ipconfig/ifconfig files.  I did a factory reset and it works now.
