DaleBuckland's avatar
DaleBuckland
Coonection
On the mywifext website, it clearlt shows that 2.4ghz and 5Ghz are not connected.
I have tried to set it up several times, all weith the same result.
Help
  • do you have a screen snip?
    Are you aware that the EX7500 is a triband mesh device?
    So in its default setup one of the 5ghz bands has a dedicated connection to the router.
    And the other 2.4ghz and 5ghz bands are just for devices to connect to?
    do you have something connected to it?
    • DaleBuckland's avatar
      DaleBuckland
      Does this help?
      My compter and other devices are connected to the internet but the Nighthawk seems not to be.
      I am not overly computer literate but I have no idea how to connect it
      IN
      • plemans's avatar
        Guru
        The extender is showing as connected but you don't have any devices connected to the extender right now.
        thats what the status page is showing.
