Orbi WiFi 7 RBE973
Reply
Dual Gigabit Ethernet Port Aggregation R8500 - Bridging in AP mode.
careyjames
my qusetion is about Dual Gigabit Ethernet Port Aggregation R8500 - Bridging in AP mode.
if i have a VERY lagre place and want the system to basically look like:
cable modem bridged>> 1st R8500 router mode using static IP>> 2nd R8500 bridged/AP mode
can I use the dual ethernet aggregate ports to connect these two R8500's???
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Dual Gigabit Ethernet Port Aggregation R8500 - Bridging in AP mode.
@careyjames LACP is not supported in AP mode.
Message 4 of 4
All Replies
Retired_Member
Not applicable
Ok so if it did work what would you gain from it? The WAN port is 1000m and since you're using them you cannot use them for a NAS.
My Nas does support 802.3ad and I'm using them. If these ports are used in AP Mode time and updates won't work because they are routed via WAN port.
Message 2 of 4
careyjames
I have no plans for a NAS, I am only looking for the most bandwidth and speed I can get from primary X8 to secondary X8 bridged downstream.
for example, if i were using a MX100 and MR53 I could use the multigiabit ports to all downstream waps...
and so this thing only allows 1g at the wan but then has multigigabit ports (that at that point are useless) ????
Message 3 of 4
ElaineM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2849 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
