Orbi WiFi 7 RBE973
Reply
EX6250 Mesh Extender doesn't connect anymore
bzyc
Tutor
Most recent Android app update made me unable to use my mesh extender EX6250. I've since factory reset the extender, and tried to reconnect, but the app keeps crashing when "personalizing settings" during setup. Have also reinstalled Android app, but to no avail. So now the Mesh Extender doesn't work. WPS can only connect 2.4ghz but not 5ghz.
Model: EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 4
Guru
Re: EX6250 Mesh Extender doesn't connect anymore
What android app are you talking about causing the issues?
Are other devices having issues or just the one device?
Message 2 of 4
Guru
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Message 3 of 4
Netgear's apps are famously flaky.
Have you tried setting it up with a browser? Wired is preferable, but if you can connect to the wifi that may also work.
One configured you may find that the app works.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 802 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
